timkroeger
Custom Title User
Hey,
at least I think it's going to be kind of difficult to do because of the building's constraints. Some background first: In two years I am going to move into a house. My brother (drums) already lives on the ground floor. I (guitar, recording) will occupy the upper/2nd floor + attic. The house hase a complete basement with concrete floor and concrete ceiling. Walls are plastered brickwall (those large bright bricks with one hole in the middle, don't know what they're called). Most walls are 240mm thick (9 1/2 in), outer walls are 365mm (a good 1'2'').
I am planning to have a tracking/rehearsal room and a control room in the basement. Most of the time I'll deal with my own rock band. My recording ambitions (and building the rooms) are to do this as a hobby in my sparetime but to do it as professional as I can all by myself. I have no budget/limit at all as I will invest in what needs to be bought but I'll be trying to minimize cost whenever possible. Not going to do some esoteric stuff... It's not going to be a business and the only timeline I can provide is I'm going to move in in 2 years. So basically I have 2 years to get my design / planning right. Even with all the reading and learning I will have to do, these 2 years should be more than sufficient I think for a small - but ambitious - hobby studio
The control and tracking room should be adjacent. I am also planning to build a sauna and shower/relax room into the basement so there are some constraints because of drains and water access. Please look at the basement sketchup below for reference. The room at the top of the picture (green floor) and the adjacent outer room to the left (blue floor) both have tap and drain, so one of those needs to have the shower built into it.
With control- and tracking room needing to be adjacent, too (and preferrably large), that leaves me with the leftmost room (red floor) and the adjacent room to the top (one of those with a drain, blue floor). Green is going to be the shower/relax room and the small room to the right (aqua floor) could be the sauna. Other rooms are not suitable due to their limit in size or installed central heating system and stuff...
Room height is 2130mm (about 6'12'') but there is a steel beam in the blue room that supports the upper floor crossing the whole room. The height is 1930mm (about 6'4'') there. Both rooms should be visually connected but I am unsure about what room to use for what purpose and what layout to choose. I am trying to lay out the constraints for the control and tracking room from what I have learned so far and what I think would suit me. Please feel free to add and comment as you see fit.
Control room:
Tracking/rehearsal room:
I thought about using the red one for control and the blue one for tracking/rehearsal. That would mean the console is facing the back wall and I'd have to crane my neck to the right to see the band. The monitors would be placed at the small end of the room. Is there another way to put the console (e.g. facing a wide wall)? Some accoustic treatment for the control room would be nice or maybe a completely different room setup. I have seen some nice studio plans at John Sayers' but at the moment I am still missing the information and practice to deduct a suitable design for myself.
I have not yet an idea of the transmission loss required to not upset the neighbours (about 15 feet from the topleft wall) regarding the tracking/rehearsal room. The other side is not so important but it might make sense to do every wall/cealing "right" just to avoid a weak link. The beam in the cealing is a thorn in my eye because dampen the ceiling will lower the height there even more and I'll need to duck to go through the room. It's not show stopper but it will be annoying.
I just wanted to post this here and see if someone has some nice ideas out of the blue. I will update this thread with the progress I am making in designing and hopefully someday building. Maybe there is an expert around who can point me into the right directions regarding console/monitor placement and room setup or weigh in with some general advice like "I'd do it the other way 'round" so I don't set up an Auralex Design just to be told it doesn't work for me
I have read so many threads and seen so many examples as well as read John's construction and design pages, I am simply overwhelmed about the approximately 1000 "ways to skin a cat".
Oh, the console with it's attached patchbay is about 1900mm x 1200mm (6'3'' x 3'12'') and I'm using Yamaha HS80M active monitors at the moment which have a bass reflex tube (do you call it that way?) at their back so I'm not sure about fitting them into an inner wall or something.
You can download the sketchup file here, if you are interested. Feel free to use it for anything you want.
Thanks for reading
Cheers
Tim
Control room:
- accoustic treatment for good monitoring
- needn't be soundproof but should block some street noise from outside (very low traffic).
- no box shape
- console facing small wall?
- need space for outboard and tape machine
- maybe elevate floor a little to route outboard cabling
- window to tracking room
- as big as can be, should also double as rehearsal room for rock band
- should be dampened a lot but needn't be sound proof
- accoustic treatment to get good sounding recordings
I have read so many threads and seen so many examples as well as read John's construction and design pages, I am simply overwhelmed about the approximately 1000 "ways to skin a cat".Oh, the console with it's attached patchbay is about 1900mm x 1200mm (6'3'' x 3'12'') and I'm using Yamaha HS80M active monitors at the moment which have a bass reflex tube (do you call it that way?) at their back so I'm not sure about fitting them into an inner wall or something.
Thanks for reading
Cheers
Tim
