A
aireq
I'm been working to record all my vinyl records to wave files. Last weekend I finally finished, with a total of over 700 recorded files. Yet when I started listening to some of the most recent recording I notice a very prominent 60hz humm. I hadn't notice before because I never listed to the recording monitor loud or in headphones. At the time just wanted to make sure I had the correct track, and that the record didn't skip during the recording. Turns out when I got a new laptop recently and set it up I forgot to plug in the ground wire from my turntable to my computer audio interface. So the last 135 recorded tracks have the 60hz humm. I feel really stupid!
Is there a way I can use some kind of processing, fillter, or eq to remove this humm from my recordings? I'm worried that simply using a notch filter set to 60hz, as some articles I've read recommend, is also going to affect the recorded audio. What would be the best way to remove this the humm from my recordings? I've been using WaveLab to do the recordings, but an open to suggestions for other software as well. I'm not apposed to just re-recording the tracks if that is really the best option, but it does take a while to record 135 vinyl tracks!
I was thinking of using this Audacity Nyquist script.
project fed: Audacity Nyquist Programming: Removing a 60hz hum
Thanks!
Thanks!
