Hi hi
Finaly some music I can relate too 100 percent.
First of all I have lots of comments/advice on this one but while listening to it I was jumping up and down my chair and shaking my arms.
Really nice song !!
I searched for your last mix and you improved like 300 procent , nice remix !!
Drums
Snare: The basic sound is per-fect it just needs some Rverb.
Send it too a bus , gate the signal (if it isnt a 100 procent drumsample) and then add up the busfader to add the reverb , DONT OVERDO it !
Kick: Could use some (more) compression.
Piano
Is fighting with the vocal in the middle , pan it out a bit.
Or a nice trick I sometimes use is: boost some fq for around 1dB almost unaudible and cut some others for 1dB or 0,5dB and cut the boosted fq with the vocals and visa versa
Rhytm Guitars
You have got the basic guitarist in there I can hear.
They really have to scream for more gain , let them cry cry and cry and then put the gain down even more.
Seriously: A nice trick is to double track them, 1 ''high'' distorted and 1 low distorted. If you turn up the LOW distorted faders you will hear the guitars comming forward.
The second one is : Treble , they always want tooooo much treble in their guitars thus making the guitars alot thinner.
But hey that's recording, about the mixing : I'd add some 1k to add some body and turn them up a bit.
Note/Lead guitar
Try to double triple or quadtriple track those next time you record.
With a tight guitar player it will sound fatter every time.
Record a MAIN take and then add some lower distorted guitars (with different eq's on the amp)
Voice
Sounds awesome.
Greeeaattt songwriting , Keep up the good work !!
