badassmak
Herbi-Whore
Well, it would appear I have got the problem under control. The whole time I simply could not get to DOS, other than using an MSDOS disk made in XP, which does not contain the FDISK command (if I remember correctly, I'm having nightmares about error messages nowadays).
I think the original boot disk I had for WIN98 must be fubarred because it doesn't read anymore.
I didn't have access to any other WIN98 machine to make a boot floppy either.
So back to bootdisk.com. I can't believe how much of an idiot I am sometimes. I downloaded the WIN98 OEM bootdisk there, chucked it on a floppy, and well that doesn't wok. Why? Because you have to double click that download, and it extracts itself to a floppy
mad: @ self)
So I hae been able to get back to DOS, re-FDISK, and Format the whole nine yards and everything is peachy, well almost. I am having a conflict between the ethernet card, and a system ACPI BIOS controller?...I think. But the problem lies in the fact that I don't have the correct drivers for the ethernet card, so I have to go to the cable company that installed it today to get some new drivers. (the drivers on site are WRONG!)
Thanks a ton for all the help |
BTW, last question here...The harddrive in question is 20G. I'm thinking I should be partitioning into two drives, one for OS, the other for apps, as stated above. When I go into FDISK, what is the correct procedure for this? Do I make two partitions under heading number 1? and assign the OS as being the active partition?
