Blue Bear Sound
No Tom, that was yellow snow!
I loved that song. "Watch out where the sled dogs go..."Blue Bear Sound said:No Tom, that was yellow snow!
Actually - the line wasAtterion said:I loved that song. "Watch out where the sled dogs go..."
Yup, you're right!!!Blue Bear Sound said:Actually - the line was
"Watch out where the Huskies go... and don't you eat that yellow snow!"
But in all fairness, almost no monitoring system will give you an accurate representation of what a mix will sound like with a sub, unless the monitoring system has a sub also. But this is a mute point, because even if the end-consumer is using a sub, the mix still needs to translate without a sub (and it has been my experience that if it translates well without a sub, it'll be fine if not better with the sub), so IMHO forget about the sub (as far as catering for it, But it is still not bad to have in the monitoring chain for checking mixes, or for dealing with LFE channels obviously (i.e. surround sound)).gtrmac said:This is especially important now since a lot of consumer systems have subwoofers. The NS-10 and for that matter, the auratone, won't tell you much about this since neither can reproduce anything in the low end.
Atterion said:But in all fairness, almost no monitoring system will give you an accurate representation of what a mix will sound like with a sub, unless the monitoring system has a sub also. But this is a mute point, because even if the end-consumer is using a sub, the mix still needs to translate without a sub (and it has been my experience that if it translates well without a sub, it'll be fine if not better with the sub), so IMHO forget about the sub (as far as catering for it, But it is still not bad to have in the monitoring chain for checking mixes, or for dealing with LFE channels obviously (i.e. surround sound)).
COOLCAT said:i disagree, if you can't hear it you don't know whats there.
if you don't have a sub and if your not getting much low-end with your monitors.....
