recording tips/MD8
  • Thread starter Thread starter Shane Wroblewsk
Shane Wroblewsk
Hey people, Just moved up from a Porta 07 to an MD8...just a bit of difference eh!("I AM CANADIAN")!Anyway any little tips would be appriciated.I am mostly require'n info about "songs" and the cut and paste procedures ect.
thanx
HEnry
Yo Shane up in Hockey Land:]
I don't think the MD8 is a great box for cut/paste, etc. I have never used that aspect of the box because fixing errors on the MD8 is touch and go, mostly GO AWAY.
I can tell you that the box does nice recordings if you have the right mic and mic pre and cables and are willing to spend time when you mix.
If I can help in any other facet of the box, ask me.
Green Hornet
hey green hornet,
so what are your favorite mics and pre's for the md8? i also just picked one up used to make rehearsal and remote recordings. my only mic pre's are two art tube pac's. i have an ok assortment of mics (rode nt2, pair of oktava s-d condensors, 57's, senn). most of which seem to sound ok, at least as good as i could expect it to sound. any other suggestions?
thanks!
tony
Yo Tony of Antonio:]
Well, man, you ask a big question which would generate many opinions. But, I'll tell you what I've used so far with the MD8.
I have an ART mic pre/two channel box; not the tube. I've discovered that if I use the 20 db boost, I get some readings on the display meter; if I just use the Art box without pushing the boost, it works but the response and pick-up depends on how much I push it in the mix.
I've used the AKG3000 mic/ and I am now using a Yorkville mic, the less expensive of the two mics Yorkville sells; however, the Yorkville YSM-1 speakers are about the best for the $$$. I had a real pro bass player at my studio last week, a good friend, and he could not believe how clear the "tape" I was playing sounded on the Yorkvilles.
For the money, I think the MD8 gives you a very creative edge; you can do things beyond your expectations if you work at it. The mixing part is the real issue. Yea, verily, there are better boxes and better systems; however for we of the struggling engineers, work, work work, and edit, edit, edit, and hope for a cool mix.
Hey, hope I've encouraged you man.
Green Hornet
Lately I've been running the Mackie CFX-16 inserts half-normalled via 8 1/4" snake to the MD-8 for our practices/jams. If I set the gain at 9 o'clock on the CFX pre-amps, I can completely turn down the gain on the MD-8 and get good vocal levels.
For the other stuff, I set the gain somewhere around "10:30" to 11 o'clock and adjust levels with the MD-8 (as adjusting the preamps on the Mackie during a "performance" would change the overall sound we hear). Mostly 'cuz we're pretty dynamic, and stuff like tambourines alternate with congas/bongos.
Oh, those levels are based on a mic-eating singer with an SM-58. The other stuff is '57-based.
Use as much gain in an outboard preamp as you can, then maybe tweak with the MD-8's preamps. Start with the MD-8's preamps on zero and adjust the outboard preamp level to unity line level.
If you tape from a board, buy a snake. I LOVE it (ROY G. BIV from left to right is what I have as default, if your snake is colored. don't have indigo or violet, so it goes Red Orange Yellow Green Blue White Grey Black).
Just a tip, I guess.
OH. Buy a white paint pen, especially if you burn a lot of discs and don't re-record. I HATE those fucking labels.
