Recording Problems
  • Thread starter Thread starter lorddrakul
L
lorddrakul
I am currently trying to do some recording and am experiencing some problems, so if any one has any pointers, I would appreciate it.
My set up is a 1.4Ghz AMD T-bird, 512Mb RAM, WinME, Turtle Beach Santa Cruz. Apps are Sound Forge 5 and Cubase VST.
The way I connect the stuff is a line out from a Marshal MG15RCD to the Line In on the Santa Cruz. I select the Line In as the record source in the control panel for the sound card. I select the default recording input in Sound Forge.
I am trying to record riffs for later cutting up and sequencing in Cubase so I have to run the drum patterns in Cubase at the same time as recording with Sound Forge. The problem is, when I do this and play back the recording, it runs at about 2/3 speed in Sound Forge despite indicating the correct time index.
When I record without using Cubase at the same time, all is well. Surely running both apps does not over tax the PC? And the card is full duplex so the outputs and inputs should not be affected.
Any ideas?
Cheers,
LD
Check what sampling rate you're recording and playing back in in both programs. In SoundForge go to file>new and look at the bit depth and sampling frquency. You probably want 44.1 kHz.
I've not used Cubase but I'd imagine there's a properties or something to check the sampling frequency.
Thanks for the reply,
I have set the sampling frequency to 44, I tried 48 but an error message said that the this was beyond the card's capabilities.
Will look around for the sampling properties and see what I can see.
Cheers,
LD
