L lascalaboy New member Aug 17, 2004 #1 If i had 4 mics on a drum kit and wanted to record simultaneously 4 tracks in CEP, would I need 4 line inputs on a sound card? - what is the cheapest sc that would have this?
Farview Well-known member Aug 17, 2004 #2 M-audio has one in the Delta series (I can't remember the name) www.m-audio.com
L lascalaboy New member Aug 17, 2004 #3 oh, using ana lto s-8 4 mic input mixer also... would I need that?
B Bulls Hit Well-known member Aug 17, 2004 #4 M-Audio Delta 44, $150. Yes you will also need a mixer with 4 preamps
L lascalaboy New member Aug 17, 2004 #5 The mixer in question is the Alto s-8 (basically the same as the behringer 1202) I think it only has two xlr outputs.. does that matter? (I'm a little consfused as you can tell..) And I have a laptop....
B Bulls Hit Well-known member Aug 18, 2004 #7 Yeh you've got enough preamps with that mixer, and just use the inserts to output to the delta 44 inputs
S Strryder Member Aug 18, 2004 #8 lascalaboy said: aha! Insert points... nice. Click to expand... That's the ticket..
