Recording Guitar and vocals at the same time
  • Thread starter Thread starter Chrisdb
yea, the 220 on guitar seems to sound ok but thats all ive ever had to chance to try out with. Do you think the 220 sounds bad?
I don't own it so, no opinion. But the swap worked with the tighter pattern up top, and the 220 sounded nice on guitar?
Wow, I can't believe I've never read through this whole thread. That's probably because the OP has already gotten such varied and good advice. The advice is varied because there are multiple ways to skin this proverbial cat. Pays your money and takes your choice:
1. You lazy bum! Just learn to play and sing the parts separately. No bleed, no problem.
2. The bleed is your friend. Avoid phase distortion by mic placement, and learn to love the bleed. Don't try fancy post-production tricks on the two tracks. Just let them be what they are.
3. Nonsense! We can defeat the bleed with better focus. Two figure 8's are usually used for this and can come very close to isolating the two tracks. A small baffle disc the size of a pop filter just below the player's chin will significantly improve the isolation. It will also annoy the guitarist no end.
4. Real men don't need no stinkin' stereo! Just get one good omni and find out where the sweet spot is. Use the California system. Move it around until the feeling is right.
5. (my least favorite) We'll fix it in the mix! We'll EQ that damned guitar until you don't even recognize it!
I have seen every one of these systems used, and personally survived most of them. I prefer #1 in most cases. If that isn't possible... here's my #5: It's the stereo version of #4- I often use a more distant, one point stereo image, either mid-side or coincedent, and find the sweet spot in the room. You need a good room for this. If the room is not so good, the mic array is moved closer, up to a point. I will record from 4'-6' distance, usually. I then build the mix from the stereo guide track. I do the MS thing with several different combos. B.L.U.E. Kiwi (fig8 or cardioid)/AKG C414 (fig8 or cardioid), C414 or Kiwi in fugure8 with Rode NTK/Neumann KM184/AKG C2000B as the cardioid. For a coincedent (X-Y) pair, I have to use small diaphragms, because (damn), I don't have a pair of LD condensers! I find the Neumann's cruel, unless you have a hell of a singer-songwriter in the house. What the hell? The beatles used KM84's that way. I used to use Oktava MC012 as a stereo pair, but C2000B just kind of took over that role.They're pretty cheap, as they go, and make a great stereo pair for guitar/vocals. Best of luck.-Richie
To me it did, why do you sound so suprised? lol
Man I am completely lost here. You said it worked and sounded good, but 'felt bad about it because of some c1000's 'rep'?
You're reading things into this. It was just a question, to move forward. :cool:
FWIW- I subscribe to the notion that all sorts of things like this, in combinations you won't know and wouldn't expect, work out just fine. The rest is mostly trim', bluff', and one 'fit' or vision of 'right' vs another.
Well I dunno how to answer all the suggestions haha...but no im not doing both seperate. I play both at the same time, thats what I do! thats how my songs work. And one without the other changes the whole dynamics of the song, if im singing quietly the guitar is being played quietly, If im singing louder naturally my struming becomes louder. Thats the point of sing/songwriters performances, and I don't want to take that away for recording.
I wanted to elimate the bleed mainly because I want some reverb on my voice and if there is guitar on the vocal track that ends up with reverb also, which makes it sound...well...bad, too much reverb for the guitar. It is very irritating. Course as this thread proves there are ways around it, guess I'll just have to figure something out. I don't have any figure 8's but maybe I should look into investing one. I think for me, I need to get a better vocal mic for starters for this very situation.
You'd need two to use them to their best advantage.
Frank
