Recording Drums
  • Thread starter Thread starter DizziDevereux
D
DizziDevereux
What is the best approach to recording drums in a medium size semi-treated room. We are using a BR-1600 with new microphones,(I don't know what kind, long story). The kit is perfect, and the room has a decent sound to it. I am just looking for general tips, since I had a general descripiton. Thankyou -- D
First, start off by making sure your drums are tuned properly. Then, a good start would be sticking some mics in front of them. :p
I'm sure someone will be more detailed than I am.
Close mic the major drums if you can (snare, kick, toms, etc.). If you have enought channels, use a pair of over heads in a stereo configuration. If not, a mono overhead is ok too. Definitely include a room mic mounted somewhere off the kit (4 - 8 feet away); and definitely play with mic position in each case to get a sound you like.
Kick Drum
In order to get good sound from your kick drum you should place one mic in the accual kick drum and one mic right by the kick pad on the front of the kick drum by the pedal. The mic you place in the accual kick drum will capture the depth of your kick. The mic you place by the kick pad by the pedal will capture the "click" of the kick drum so each kick sounds solid.
hope this helped
room mic?
:confused: :D
whats this thing about the room mic tell me more?!
placing a mic (usually a LDC) away from the kit will catch more room sound (reverb and a more overall sound of the kit) and when used properly it gives more depth to your drum tracks
never had the chance to try it myself though
The more mics you have, the more phase problems you will have. If you really know what you're doing, a gazillion mics can help get a huge killer sound. However, if you're just starting out, you may want to do a search on recorderman's minimalist mic technique for drums. It's simple, counterintuitive, but yields really nice drum sounds.
In a nutshell: put a nice condensor mic (say, an SM-81 for example) exactly two drumstick's length above the middle of the snaredrum. Put another condensor mic just over the drummer's right shoulder, pointing down at the snare. It too should be two drumstick's length in distance from the snare center. Put a nice dynamic mic in the kick drum a few inches off the batter head, preferably something with a nice round low-end like an AKG 112.
I was amazed at how round full and fully in phase this approach is. I am starting to use it with great success, although I usually stick an undersnare mic into things as well, for added crispness. Unless your drummer is totally nutso, you won't hit these mics inadvertently.
And oh, yes, the comments about drum tuning are gospel. A good kit, in a nice room, tuned expertly, played by a good player, into good mics, that are well positioned, fed into a nice preamp, into a nice A/D converter is the ticket.
Good Luck!
Yep, that's my experience. I'm in a small room that's pretty dead and the overheads tend to be a little dull sounding. Using an LDC away from the kit tends to pick up alot more high end and make the overall kit sound better.
Since I've got 10 inputs to work with any time I'm tracking drums, I'm of the persuasion to try a whole lot of different mics at the same time and then after tracking, choose which combination works best. Frequently when tracking, I'll have a mic in the kick, one on the beater side, one on snare, one on each of the toms, two overheads, one on hats, and one room mic. Then afterwards, I'll decide which combination of tracks gets me closest to the sound I'm looking for. Once I get 6 more pre's, my track count will be up to 16 and I'll have more options than ever.
Thankyou all for your input. I will certainly utilize your responses and hope for the best. This is a good thread. ------ dizzi
