			c7sus
Disenfranchised Member
As far as the second clip goes, I think that is the self-noise of the mic you are hearing. And I had to crank my monitors to -5dBVU at unity gain on my 1402 to hear it, with the looped clip playing full volume through Winamp! My wife couldn't
*hear* it either until I turned my amp up to -2dB at unity from the Mackie. AT lists the self-noise spec of the 2020 at 20dB SPL.
http://www.audio-technica.com/cms/wired_mics/a0933a662b5ed0e2/index.html
However, I can see how once you get dialed into that sound it would get annoying. Another solution that might take out at least some of that is judicious use of gating in post, which I would imagine to be pretty tricky to dial in and not wind up cutting off some dialog. Of course, the preamps in the mixer you are using aren't anything to write home about either. But the solution of new interface/upgraded preamp/ and possible something-else mic seems like a lot of bread for very little gain audio-wise.
Check out this thread, and specifically post #19.
https://www.gearslutz.com/board/so-much-gear-so-little-time/421377-mics-low-self-noise-help.html
