Reaper, is infinitely adjustable I am told so you can probably fix that. Samplitude Pro X6 has several meter variants.I just checked Reaper and my fader meters go straight from green to RED! LOOK OUT !
Yah listened to River, friggin awesome soundingI record a little hotter at -16dBFS - in fact I posted a song that the daughter and I did where you can see the results.
River by Maggie
have you actually tried recording at the middle and two extremes of your gain range?Hi, just wondering what levels everyone is trying to record at. I have read a lot about this subject and am finding answers ranging from -18 db to as hot as possible without clipping. I am using a Zoom r24 and Behringer ultra gain 100 preamps with an Ldc mic.
Guy
That’s good advice. I actually just started trying to do some comparing the other day and will continue that until I get some sort of results I can use. Thank youhave you actually tried recording at the middle and two extremes of your gain range?
have you listened to the sound of the hot recording, versus the very conservative recording, versus the more industry standard -18LUFS with at least 3-4 db of headroom?
you will decide based on your own experience.
when you use low end convertors and preamps as the ones you describe,
i would err on the side of conservative.
24 bit recording allows for very low level recording to be brought up without bring much noise.
if you have good source tracks, and good convertors.
Thank You.Yah listened to River, friggin awesome sounding
You treat -18 dBFS like we used to treat 0 dBVU, as the signal's approximate middle point. It should spend time above and below that mark. For percussive sounds, maybe focus on the peak level and keep some space between that and 0 dBFS.Well, digital recording along with pretty dead quiet mic pres in even basic interfaces gives you a lot of room to adjust things after the fact, but -18dB doesn’t mean much by itself. Is that peak? RMS? LUFS? Eyeballed nominal? And, then what and/or who are you recording and what will you do with the tracks? An experienced session player can be dialed in tightly while your buddy from high school probably needs a little more room so the stray peaks don’t clip.
