Record a small tube head through my Line 6 UX1
  • Thread starter Thread starter Kalsten
K
Kalsten
Hi
I am about to buy a small tube head + cabinet to play at home (Randall Diavlo RD1H). It has a dummy load to connect to interfaces and record yourself in the computer, but I am a bit confused about how to connect it to my Line 6 UX1.
The Line 6 UX1 has three connections in the front: a XLR Mic, a Jack for the instrument, and a Jack for Headphones. The Randall RD1H has a XLR out speaker simulator. Do I need to buy a XLR-XLR cable, and connect it from the out of the amp, to the Mic XLR of the UX1? Or should I buy a XLR - Jack, so I connect it to the Instrument input of the UX1?
I am a bit lost with all this, and I cannot find any answer anywhere.
Here it is the instruction of the Randall, if you need to read them: http://www.randallamplifiers.com/downloads/RD1H_RD5H_RD5-112-Manual_110514.pdf
Thanks you very much :)
XLR-XLR. Keep the input gain/volume on the UX1 down low when you turn it on, then gradually increase the volume.
Better would be to put a mic in front of the cabinet speaker.
Grrr! The Randall manual does not give the output level of the XLR* socket. They do however say it can feed a power amplifier so we can assume somewhere between -10dBV (300mV) and +4dBu (abt a volt).
The former figure would be hot for a mic input but probably "safe". The latter would almost certainly cause cracking, unpleasant overload but there is no harm in trying.
I really do wish gitamp mnfcts would give XLR outputs MIC levels and floating, transformer outs, not as tho' suitable traffs are that expensive!
Yes, I know some top level "pro" gear uses XLRs at line level but most stuff these days don't. You see "XLR", you think "mic" level.
Thank you for the answers.
Do I need to buy very expensive XLR-XLR cables? or any price would work more or less the same?
Nah! Any of these..https://www.amazon.co.uk/Stagg-SMC10-Quality-Microphone-XLR-XLR/dp/B0030LYVZG
will serve. They do not have the top (mechanical) quality "Neutrik" connectors but are easily good enough for light home duty.
If you were prancing about on a stage every night with a mic you WOULD do well to go for a better build of cable but even then a 10mtr one should not be above $20 US.
