Recommendations On A Boost?
  • Thread starter Thread starter gcapel
gcapel
gcapel
boom box recordings
I been thinking of buying a boost pedal. I use single and humbucker guitars and only use tube amps. I built an LPB1 years ago. It about the only boost pedal i have used. Does it get much better? I would also most likely use it as a clean boost.
Id think that is the most you can do for clean...I bought one once and it made my montgomary wards amp alot louder...lol.
MXR Micro Amp does a great job and the price is awesome.
I run it before my OCD to let the amp overdrive slightly naturally with the OCD off and push the OCD harder when it's on.
BBE Boosta Grande. True bypass, made in USA, power supply included, 5 yr wtty, clean and uncolored, under $100.
IF you cant afford the Barber, that is..... :D
