FALKEN
can somebody please recommend an outboard limiter for vocals on mixdown and possibly for stereo mixes? thanks!
FALKEN said:1176 eh? thats like, $1000 for *one* channel right? you need a pair to do a stero mix? how bout under a grand for 2 channels?
the dbx's are "peak" limiters, right? is that different from "program" limiters? I am probably going to be limiting quite a bit..not sure if there is really a difference.....although yeah dbx's sound good and I have considered picking up a couple more channels.
. Try your luck at ebay too, you'll never know what you might come up with.
(also this sounds great with almost anything). Both are mono. If you want to have a good stero/mixbuss compressor, prepare to spend some $$$. They aren't exactly cheap.. Think this as an investment. Good analog hardware usually retains it value very very well (way better than cars
).Kainz said:MONO:
- 1176 clones (colored all-around basic compressor with tone, not so great on mixbuss unless you want to have something not so clear)
- LA-2A clones (colored and more "limiting" like, another basic studio workhorse)
- Distressor (very versatile compressor, maby not the first to go with the vox thou; go with 1176 or LA-2A)
- API 525 (nice little comp.)
STEREO (mixbuss):
- Crane Song STC-8 (this rocks!)
- NEVE 33609 Limiter/Comp (veery nice too!)
- API 2500 (basic stereo comp, good for mixbuss)
- GML 8900 (again very good stereo compressor)
- Buzz Audio SOC 1.1 (no experience from this one)
. (Mixing the PMC11 with this setup wasn't exactly "optimal" lol; fortunately I have the Dynaudio BM6a monitoring and quite nicely acousted room. Need a bit more $$$ and I'm starting my own studio building project).ozraves said:
SonicAlbert said:The Dominator is good, but it has kind of a hard sound in my opinion. Have you considered the Waves L2 hardware? Great for mixdown.
SonicAlbert said:Most compressors are compressor/limiters. If you crank the ratio up high enough it becomes a limiter.
I'm assuming you want something to do levelling? Even out vocals, mix, etc?
I'd suggest you take a look at the Aphex Compellor rather than the Dominator. The Compellor is kind of a unique beast, and I personally think it sounds better than the Dominator. I have both, by the way. The Compellor does really nice levelling and is virtually invisible when doing it.
My favorite Aphex processor is the Expressor compressor/limiter. I have four of those, good units. But the Compellor might be more suited to what you are looking for.
FALKEN said:I guess it wouldn't be HR.com if someone didn't throw in the RNC.
FALKEN said:compression is good but I think a good hard limiter on those 2 instruments (naturally the loudest in the mix)
