davidthangjam10
Could you guys explain to me the meaning of reamping guitar? I've heard alot of these words in recording techniques but i dont have any idea about it? and could you tell me how do they reamp guitar. Thanks in advance
I always suggest just plugging the recorder/mixer straight into the amp first.
And this is how the argument always runs. There is almost always some volume control on the way out or the recorder. All that matters is the voltage that reaches input of the amplifier, whether the hole it's coming from says "Line" or anything else. My only point is that, if no other problems exist in the system, a straight cable should work fine. It's something we already have. Plug the damn thing in and try it. Be a little thoughtful and patient in tweaking levels. If it works it's free. If not, go get one of those boxes. Doesn't bother me in the least.
Me? I'd just insert PodFarm2 and move on.
Like I said, been down this road so many times I should know better. .
Yeah, you should.
You guys could complicate a glass of water.
That's all really great except for the impedance mismatch part.
I've never done it, myself.??? We have not "matched" source and sink impedances in audio for decades.
it's not just the level actually. If that were all it was you could simply turn the line level down until it was as low as an instrument signal.So, use what? Line out? That's doable, but for the most precise re-amping you need to get it down to instrument level. That's basically what re-amp boxes do. Feeding an amp line level won't blow it up, but if part of the point is to simulate the guitar part actually being played and having the amp react accordingly then you need to feed it a signal on par with what a guitar pickup puts out, and that's way less than line level. Feeding an amp line level is similar to using a clean boost or OD pedal in front of it. That's my take on it anyway. If you feed the amp line level and can jockey the gain and what-not to get a result you like, then knock yourself out. I dunno, I wouldn't do it. I'd want to feed my amp a signal that it will happily accept all day long - like a a guitar input signal, which is considerably lower than line level.
Aren't most pedals that aren't true-bypass buffered?I've never done it, myself.
We want the load impedance to be at least "higher enough" than the source in order to get maximum voltage transfer. A typical guitar amp is quite a bit higher than higher enough for a typical line out. Technically it should be even better than running into a low-Z line input, but there's a certain point of diminishing returns.
Nobody ever worries about "impedance mismatch" when plugging the low-Z out of a guitar pedal into an amp.
BTW - I'm not completely clear on how "just plug the damn thing in" is more complicated than using a reamp box.
Unless I'm mistaken ( I may be since I've never done reamping) but unless I'm mistaken a big part of a reamping device is impedance matching. An amp is designed for not only an instrument level signal but also the impedance you get with a guitar on the end of a 15 foot cable. That's a very different impedance than the line level send out of a mixer.
But even then all it might possibly affect would be freq response so I'm kinda with ashcat on this ..... just run a line level to the amp and see.
But, once again, I've never reamped anything so I don't have personal experience with this.
I'd have to care about my recordings to go to all that work to change something I'd already recorded.
for sure if I wanted to start using this I'd buy a reamping box. There are some that don't cost much.That's why a reamp box is beneficial, or at least running the line level through a buffered pedal for the quick and easy route. There's all kinds of ways around it. But just running straight line level into the amp can be noisy and it's just fundamentally not the right way to go. If it works for someone, great. I'm not saying it can't. But if someone asks about reamping, giving them the haphazard way to do it isn't the best idea IMO.
