R
Randaji
I understand the general idea of reamping a guitar track and I've done it with decent results. I hear often that you really need a "reverse DI" like Radial's X-amp or the equivalents from Little Labs or Reamp. As I understand those devices do 2 main things to allow your Multitrack output to feed your amp:
1) Convert low impedance (track output) to high (Guitar amp)
2) Pad the output so the amp is not overdriven
An optional 3rd might be ground lift.
If I'm generally correct about that, then I'm left wondering what I'm really getting for $179+. It seems like I can avoid overdriving (#2) by just reducing the volume of my track output. And though I understand that guitar amps are generally designed to take a high impedance signal from a pickup, most of us actually drive the amp input with pedals most of which have a low impedance. Since it's usually fine to drive a high impedance input with a low impedance output, why should I need an extra box to go from my audio card to my amp?
Just curious if anyone knows of a real sonic advantage, or if it's somewhat snake-oil or a piece of gear that just makes reamping more idiot-proof.
Also, does anyone just go direct from their audio card to their amp?
Thanks for any enlightenment you might have.
