P
protein
just record it at the studio it will always be better.
Thanks man.
I suppose its a good idea for us to DI the tracks at our own studio then bring them into the studio and try out re amping and also try out normal recording. This gives us the most options.
So would you say I definitely want to get a DI box and a re amp DI box?
What could be the outcome if I didn't use these boxes, and could I not sure a DI box as a re amp box?
One for question, sorry.Could I use a box like the ART Tube pre amp as a DI box or would it be best to use a dedicated DI box?
Thank you,
Eck
can you possibly get by without a DI and Remap box? sure.
but these devices are designed for this purpose and used correctly will ensure proper interfacing.
you won't need a Reamp Box if reamping at the studio and the studio has one. if the studio doesn't have one... hum
it's a good idea to have a descent DI box.
I'm not familiar with the ART stuff.
I can't say this enough... don't assume that because you are at a Professional Studio, you will get a superior outcome. if the Engineer is not experienced with your Genre, you may end up sounding like what the engineer usually mixes. I've recorded numerous bands because their Professional Studio experience and outcome did not meet their expectations. the recordings sounded good, but were not mixed for the Genre. FWIW a rule of thumb, the engineer influences more than the studio.
Be sure to bring in a CD that you like... as the mix template. Don't settle for less.
Good luck.
There are two things that you have to get straight in order to re-amp correctly:Would turning down the fader on the channel to be re amped not work fine as a line out straight into the guitar amp?
Eck
What pickup and tone setting do you normally play it with?maybe I am.From my experience changing the pick up selector and also making small tweaks in tone knob can make a huge difference in the recorded tone. Ive never re amped before though.
You are second-guessing yourself to death. If you really don't know what direction you are going, you might as well just play the part at the studio.
BTW, if you have passive pickups, you need to be using an active DI.
I listened to the stuff on myspace, it really doesn't sound bad. There is a general lack of midrange in the guitar tone. If you took it out in the mix,
that's great. If that's your guitar tone, I can see why you think it's muddy and harsh at the same time. Turn up the mids and shut off the 'scoop' switch. You might want to turn the gain down and turn down the mic on the bottom of the snare.
1. Level
2. Impedance
You can adjust the level any number of ways, but if you don't have the impedance right, the amp won't react the same way as it would if you were plugging a guitar into it.
If you have an impedance mismatch, it will throw off the frequency response. You will load down the pickup and lose high end.Sorry for my ignorance but what exactly is the reason for having the right impedance? I dont really know about any of this.
Eck
It's because a DI box is designed to take a high impedance line level signal and bring down the impedance and level to that of a mic signal. When you hook it up backwards, you are taking a line level signal (not a mic signal) and raising the impedance and level even more and trying to jam that into your amplifiers input.
It's kind of a trick to get the impedance to go up with the level going down. Since re-amp devices are specialty items, no one really makes a crappy one that would sell for cheap.then it's probably a good think that i have almost never in my life re-amped anything.
and re-amp boxes start at like 200$ wtf is up with that.
1. Level
2. Impedance
If you have soapbar pickups, they are not active. Unless you have a 9 volt battery that needs to be changed every so often, you don't have active pickups. That might also be part of your tone problem. Soapbars are not the most 'metal' of pickups. They are more of a classic rock, jazz sort of thing. They are single coils, that's why you are having a problem with the Marshall.
It's a really nice guitar, but not the first choice for metal tone. Try something with some humbuckers and see if your marshall gets closer.
Oh, and getting back to worrying about the pickup selector and tone control position for the performance track:
At some point you just have to make a desision and live with it. If you have no idea what you are going to be reamping through and/or what settings it will have, you have no way of knowing which pickup, etc, etc... You should just do what you normally do and tailor the sound of the amp/mic/preamp/etc... to what you have laid down for the DI track.
Decent transformers cost money. Just A/B a whirlwind imp ($30 passive) with a Radial JDI ($200 passive) and you will hear the difference.
That would be a DI box.that being said...does anyone know of any affordable devices for dropping a balanced line level signal to a balanced mic level signal?
That's 3 $200 boxes in one rack unit. Makes perfect sense.I did notice the expense of good DI boxes and re amp boxes woah!
I was one that was $600!! It was pretty much a DI/pre amp/re amp box all in 1 but still thats an expensive wee box.
Eck
