Re-amping
  • Thread starter Thread starter Blor007
B
Blor007
Hi,
What do you need to re-amp a guitar and will it be a bottleneck on the overal quality?
I'm thinking of recording a perfect take and then sending it to a professional studio to re-amp the guitars.
Do you think that that's a good idea?
If you're not doing the re-amping, all you need is a direct box (assuming you have a pre-amp already). You just need to take care to capture a clean and pure signal from the guitar.
If you're doing the re-amping, you need a re-amping box which will bring the line level signal to instrument level for feeding it into an amp. You can get a dedicated box like the X-AMP from Radial Engineering, or a few others.
You can also use a passive DI box in reverse, but an active box is best for recording the DI so it's not a good idea to try and kill 2 birds with one stone.
It is not a bottleneck in any way. It's the same quality you would expect from mic'ing an amp the first time around, provided you do everything right.
You can get guitars re-amped by Michael Wagener (Ozzy, Metallica, etc, etc.)...He's offering that service now. ;)
Hi,
Thanks for the explanation
I have this: http://www.zzounds.com/a--2676837/item--BEHDI100
And an Gyraf Gyratec with Line input. (pre-amp)
My main concern about the gyraf is that the tubes alter the sound?!
And my main concern about behringer is that it's behringer ! :P
What would be the best use for those to track down a clean signal?
You shouldn't have any problems using the Behringer DI box.
For that matter, the tube pre would probably be fine too if you kept the signal as clean as possible.
Do what Gilmour did. Rent a stadium and blast the track through the PA system. Set up 14 microphones and re-record. :rolleyes:
I tried the stadium thing....highly overrated. For the amount of effort required I thought the sound was no better than running direct through a POD :D
