montage
I'd like to attempt to re-amp guitar and bass tracks and I'd prefer to have someone review my setup before attempting anything:
1) Record track(s) to PC running Sonar via Delta1010LT soundcards.
2) Prepare track for output; through RCA out from soundcard.
Change connection from RCA to 1/4" to input of amplifier.
Now I have a couple of thoughts/questions:
A) Should I (depending on strength of pre-recorded signal) leave Sonar's fader on zero and adjust volume via the amplifier? Having the fader too hot would affect the input gain before the amp, right?
B) Should I utilize a direct box (I have DOD AC265 Direct Box) inline as part of my connection. It has a ground-lift switch and an attenuation (0,12,40 dB) pad switch. Also I was thinking of using a very short connection from the RCA-out from the soundcard to 1/4", then on the other side of the direct box I can use a sheilded guitar cable.
Anything else that I should consider before trying this?
Thanks for all replies.
