R
rfahey86
It also helps if you bounce the drum tracks to audio and then disable DFH. Using the files dosen't take up nearly as much ram as the VSTi.
you can find us on www.ProjectHellCow.com,
I recommend checking out the Studio Build forum and learning more about egg cartons for acoustics. They're basically worthless and a fire hazard.
(I grew up about 30 minutes east of you)
Cheers,
. We didn't have recording in mind when building the room. All we wanted to achieve was keeping most of the sound in the room as to not bother the rest of the house. The room is fully insulated, sheet rocked, ceiling tiled, carpeted, and egg carton'ed. How much do the egg cartons help? Probably not much. But for now we are happy with the sound; you can only hear the bass upstairs.
I usually learn the hard way anyway![]()
We're located in a hidden secret layer in the state of CT. We whore ourselves all over the internet though; you can find us on www.ProjectHellCow.com, as well as facebook, myspace, and twitter!
Which video have you seen, and what do you think?
LOL, that's usually the way it goes....
Fortunately, treating your room for acoustics (not isolation) is not too expensive. If you are a DIY'er, which from the egg cartons I see that you are, then you can probably treat your room nicely for less than $200. Some OC703 or equivalent and some cheap fabric from walmart, some spray-on adhesive and a few other little things and you're good to go.
Good luck and have fun.
But that's a whole new thread... so, time to do some research!
It's always recommended to use a separate physical drive for your streaming audio. Your O/S and DAW on one drive, your audio files on another.
Well if we go the acoustic treatment way, we would go balls out. Wouldn't we need bass traps as well? If i can get a figure on the total cost for proper (or as close to proper) acoustic treatment I might actually go ahead and replace the egg cartons you all love! We'll make it a video and feature it on our website to bootBut that's a whole new thread... so, time to do some research!
Mike
Back on topic... upgrade the ram and disable useless background services. Let me know if you need help with that![]()
And you can use OC703 for bass traps. 4 to 6 inch thick straddling the corners.So for instance lets say i record a guitar track ...
can i record it straight to my external hard drive....
or record it to my hardrive and then move to the ext. hard drive after and insert back into my working file?
Would this improve perfromance?
Can i even set reaper up to record to me ext. hard drive?
