Farview
Mystery solved.
That's the strange part... the interface is fixed point, so anything above 0dbfs should clip the converters, even if it isn't clipping in the box.
The only thing that would stop that would be if samplitude was scaling the signal to match the converter's limits...which no other daw does. I will test this out on my version of samplitude in a couple weeks.
All daws run a floating point bit depth internally, but it gets converted to fixed point for the converters. Unless the daw is scaling the output, the converters will.clip. if the daw is scaling the output, then the metering is useless at that point.
On my DAW, with a Lynx AES16 PCI card and Aurora 16 converter, the Lynx meters matched the Samp Pro X meters perfectly. No clip indication all the way up to 0 dbfs, and then a clip at +0.1 dbfs.
However, I had a different situation on my laptop with an Echo Indigo IOx that I use as a headphone amp/ASIO driver. The Indigo has 8 virtual outputs and a master. The 1-2 virtual output meter matched the Pro X meter, but the master out was down by 3 db on the meter. The Indigo meters don't have any clip indication, so I couldn't test to see if it matched the Samp meters. Just for fun, I pushed up the Pro X fader to +12 and the Indigo master meter stayed at -3.
I have no idea why this discrepancy exists, but I always record and mix at low levels, so it's never been an issue for me.
Seems like maybe your hedging your bet' a little (? :>) Between 'it doesn't clip' (as long as i wasn't 'rendered), and 'didn't sound like it clipped'? :>)I'll have to do a little more checking...but Echo has always done things a little "differently" with their interfaces/converters than everyone else....slightly different design approaches.
TBH...as I said, I've never bothered looking into it before, I just don't ever recall hearing my DAW setup clipping from too much level.
I've had it hiccup and stutter by overloading it with processing/FX or multiple real-time samplers...etc...but never had a problem with clipping.
The trouble is...Echo stopped making interfaces/converters...and the Layla24 boxes are like 3 generation back from their last product line...so it's kinda hard to get detailed info about the inner workings. I tried Googling a bunch of things about the output levels and the metering...and didn't find anything so far.
I was thinking maybe this could have meant 'could have clipped, just never noticed'.TBH...as I said, I've never bothered looking into it before, I just don't ever recall hearing my DAW setup clipping from too much level.
And you did say rendering was totally different.Again...I had the DAW slamming at +12 dBFS...the soft console for the converter set at the normal +4 reference level, and there the meter only goes to 0 dBFS....regardless of what I was seeing in the DAW.
So all in the red, cranked...and NO digital clipping.
I know it was LOUD as hell, because I had to turn my Monitors way lower to keep from blowing out my ears from their usual monitoring setting...so yeah, it wasn't just a visual metering thing...there was some serious volume, but still no digital clipping.
That said, if I bounce out an audio file like that...and then play it back, it's clipped to the max.
Somewhere in there is the key .. guess :>)
Can we make a Cliff's Notes in layman's terms?
It's clipping, but doesnt sound like it's clipping when playing in the daw.
Now why it's not heard in the daw.....I have no idea. Nor do I care.
