dobro
I'd like to know more about Q. One definition I've heard is that Q is frequency divided by bandwidth. Okay, so if your parametric is centered on 1000 Hz and your bandwidth is 750 Hz, with the lower end on 500 and the upper limit at 1250, then the Q is 2.
First question: so, that means that if you center your parametric on 2K, a Q of 2 means that you're covering twice as much bandwidth (2000 divided by 1000 = 2). Have I got that right? Q is a shifting value depending on the center frequency?
I'd appreciate an answer to the above, but the reason I'm posting this is because I want to know how much of an octave I'm affecting when I set the Q at 2 or 3 or 4 or...
Does a Q of 2 affect a similar octave range no matter what the center frequency is?
