W
whattaguy
I was looking at the Vantec Stealth case fans.
Fan Size: 80x80x25mm
Rated Voltage: 12 V
Rated Current: 0.08 Amp
Air Flow: 27 CFM
Rated Input Power: 0.96 W
Noise: 21 dBA
Rated Speed: 2050 RPM
Bearing: 2 Ball Bearings
Is the 27 CFM going to be sufficient to cool off my system
P4 2.4GHz cpu,
512 RDRAM
2 HD
Aardvark dp2496
ASUS P4T533-C mobo
The 3 stock fans that came with my Enermax case are pretty loud, but cool off my system nicely. Currently, the system peaks at about 100 degrees F.
Thanks, all of you kind, kind people!
Rated Voltage: 12 V
Air Flow: 27 CFM
Noise: 21 dBA
P4 2.4GHz cpu,
512 RDRAM
2 HD
Aardvark dp2496
ASUS P4T533-C mobo
