Ha! I had to go back and reread your original post because all I did was check out the picture of your awesome Dano.
Yes I do/did have that same problem with mine. I figured it was because, as others have said, the pickups were probably identical, and the string vibration at the neck is much greater than at the bridge. I adjusted the heights of both to compensate for it, but the neck is still a bit louder. It's livable though. If I remember correctly, the middle position on mine is the loudest of all.
