A
AASteveo
it's hard to get overheads in the exact perfect place for the snare sound to reach each mic at the exact same time. a lot of amateur mixes have shitty snare sounds. one of the more common problems is phasing due to bad mic placement. here's an easy fix to this WITHOUT any EQ work.
1) first go into pro tools and solo up the overheads and the snare.
2) then find a single snare hit without much other stuff going on. zoom way in on the snare track and then tab-to-transient. write down the location of this transient.
3) then solo up the overhead left track and zoom way in. find the exact same snare hit and put a sync point on it (command+comma). now go into spot mode and put the sync point at the same spot where you wrote down from the snare track. you could also shift or nudge or just drag the region, however you want to do it.
4) do the same for overhead right.
basically, just match up the transients in the snare track and the overheads.
if you have each track exactly in phase, it will be much cleaner and the snare will cut through and sound incredible.
if you have two sources that are delayed slightly, you will get comb filtering and there will be phasing issues. most people might want to immediately grab the EQ to fix it. you can't boost frequencies that have been cut out due to comb filtering. EQ will never fix phasing from bad mic placement. if you don't believe me, just duplicate any region in protools and nudge it a few milliseconds and see how extensively the EQ changes. one millisecond can make a world of difference!
so now that you've done this with the overheads, try it with the room mics. not to the snare track, but just with each other. any time you have two mics on the same source, match up a transient so that they are in phase. this helps a lot with the bass DI vs. the bass mic. they are almost always delayed slightly. now that you know this trick, you can put as many mics as you want on any instrument and never have any phasing issues!
