C
Chris.
I have attached a picture below and I'm just curious as to something strange going on in my room. The room is not to scale and I don't know off the top of my head the size of it, but I will measure when I get home. I think the room may be a little bit longer than drawn.
The center imaging out of my monitors is off to where the left monitor sounds louder than the right. Not only that but if I put something center it seems to lean to the left instead of staying right in between. If I mix to balance those out and then go listen somewhere else the left side is quieter than the right to compensate, so I know it is definitely my room situation.
In the below diagram the teal colors are Minitraps and the red ones are Microtraps. The minitraps are all at the correct angles (more accurate than in the picture) except for the upper left one which has to be at an odd angle due to the book case. The Microtrap on the left is on a mic stand with probably 12 inches of space (mic legs won't let it get any closer) and the one on the right is hanging from the wall with about 3 inches of space.
I'm guessing the book case has something to do with the skewed stereo image? Also maybe the closet and how it's on the left side and not the left? I'm thinking it would probably be a good idea to put the book case straight behind my mixing position on the far wall. I hear book cases are good for diffusion or absorbtion or something like that?
http://www.ffaudio.com/img/room.bmp
