G
Greg_L
Banned
I didn't see a question.That's not what I meant, but for having posted several times on this thread it's amazing that you haven't contributed one bit to answering the original question.
I do. That you don't think it's possible explains a lot about what you're doing.but who seriously thinks they can capture a tone that will sit exactly how you want it to in a mix? Be it guitars, or else.
Is that actually what you're doing? Didn't you say "I use AxeFX"? I read that to mean you're tracking your own stuff. So which is it? If you're tracking it yourself, get it right.If your (or anyone else's tip) is to capture a better signal going in, so be it. And that's great if you record your own stuff. When you're given a project to mix, you work with what you got,
And you got a shitload of wide ranging answers.and I'm after the techniques that help open up a mix a bit. Maybe it's less buss compression, mid/side balancing, better eq, etc. maybe it's using a lower tuned snare so the stick attack doesn't land right where the bite of the guitars is, helping it cut through better, maybe it's all those things, I don't know. That's why I'm asking.
It is for real. It might sound strange or extreme, but it is not. You need different frequencies of the same sound source for the sound sources on the side (no extreme settings) and the same frequencies for the sound sources in the center. This is how the brain can separate out what sound sources are wide out in the stereo field and what sound sources are in the center. The density of the side panned instruments ensure the mix does not pump towards the center by allowing more dense sound sources in the center mask those side frequencies. Having said that, what kind of sound you prefer is a matter of taste, but I personally like rhythm guitar to be wide and enhance the size of the mix as a whole, I can understand why the topic is being studied.
