G
Greg_L
Banned
I didn't see a question.That's not what I meant, but for having posted several times on this thread it's amazing that you haven't contributed one bit to answering the original question.
I do. That you don't think it's possible explains a lot about what you're doing.but who seriously thinks they can capture a tone that will sit exactly how you want it to in a mix? Be it guitars, or else.
Is that actually what you're doing? Didn't you say "I use AxeFX"? I read that to mean you're tracking your own stuff. So which is it? If you're tracking it yourself, get it right.If your (or anyone else's tip) is to capture a better signal going in, so be it. And that's great if you record your own stuff. When you're given a project to mix, you work with what you got,
And you got a shitload of wide ranging answers.and I'm after the techniques that help open up a mix a bit. Maybe it's less buss compression, mid/side balancing, better eq, etc. maybe it's using a lower tuned snare so the stick attack doesn't land right where the bite of the guitars is, helping it cut through better, maybe it's all those things, I don't know. That's why I'm asking.
