T
tf5_bassist
The LouDogg
alright, I've been curious about this for quite a while... so say that you're using your DAW, and you have something like an MBox, or q10, something with pres in 'em. Then you end up splurging for an RNP, Grace, or something definitely better than the built-in pres. You could just run that new orgasmic pre to the previously only slightly-arousing pre that was on your A/D, right? I've been wondering whether this would entirely defeat the purpose of having that new pre, or if it'd be fine if you left the lesser quality pre at a lower nominal setting, or whatever. Or do you have to go straight into an un-pre'ed input?
Same question goes for running into a mixing console for tracking to a 8-track deck. can you run through the existing pre, or should the new pre run into the line input on that channel?
I'm sorry if this is a rather stupid or nonsensical, or common sense question, but i just honestly am clueless on this.
