What noise? The noise from the converter, as I said. No converter is 24 bit quiet - or even close - and probably never will be due to the laws of physics. Many if not most consumer level converters have noise levels much closer to 16 bit than the theoretical 24 bit. So THAT noise. It's not non existent. At 24 bit tracking it IS the noise you are dealing with at the bottom end, even before you have connected anything to the converter's input.
Once again, the best regime for maximum headroom is to make sure your preceding analog stages' own self noise just masks this converter noise and no more. That is the proper engineering/ gain staging method. And as a rule it will probably result in tracking levels lower than even you track at!
My converters sit at around -110dBFS with the chain connected and individual units bypassed. The converters aren't making noise. The analog gear is making noise. The "noise" of the converters is insignificant at the very worst.
ANYWAY - Let me dumb this down to the dummest-downiest that I can because for some reason, some people aren't even grasping the basic concept here: It's not even apples and oranges anymore. It's apples and things that don't even resemble fruit. Like hubcaps or something.
THIS WILL REQUIRE SOME AMOUNT OF GUITAR AMPLIFIER EXPERIENCE.
A typical Marshall stack. Everything on - pick a number - 7. Except the preamp gain (which is on ZERO at the moment). The noise you hear is the power amp. Let's say for the sake of argument that it's sitting at 50dBSPL at one meter.
Turn the preamp up to TWO - The ambient noise level is now at maybe 52 or 53dBSPL. The guitar sounds open, clear, focused, undistorted, sparkly - Pick an adjective. Play it soft, it's clean and clear. Whack the hell out of it, it's still clean and clear - Dynamics for days. A clean signal going through the preamp without fear of it distorting. It's called headroom. Note that the ambient noise barely rises (if it would even rise the 2 or 3dB that I figured as an example).
Now turn the preamp up to SEVEN - The guitar sounds "tightened" and "crunchy" without the clarity and focus, without the open dynamics. Play it really, really softly, and it might still have a little "sparkle" to it. Whack it hard and it's edgy, distorted, bordering on fuzzy - and the ambient noise is now 70-75dBSPL.
GRANTED - WITH A GUITAR, this might be exactly what you're looking for. With the microphone trying to capture the sound of the amp (or anything else), it's not. GRANTED - this is a relatively 'harsh' example, as guitar amps are actually designed in many cases to distort 'on demand' for creative reasons.
The distortion increased when the preamp gain went up. The NOISE increases (dramatically) when the PREAMP gain goes up.
The sound loses clarity and dynamics as the preamp gain goes up.
The AMPLIFIER (for the sake of argument,
whatever the next item in the chain may be) is still on "seven" and is making the exact same amount of noise it was before. It's no noisier - The SNR is exactly the same. It's the SIGNAL BEFORE IT - the PREAMP and what's in front of it that's making the difference.
I hope I'm making myself clear (and focused and dynamic) on this...
