question about track bouncing on tape
  • Thread starter Thread starter groucho
Hi all - I've resolved this one fortunately. I'm now very happily using a Tascam 488, which is plenty of tracks for what I'm doing. I still am doing a wee bit of tweaking to the final stereo mix once I get it to the DAW but I think I can live with that - I mainly didn't want the puter involved in tracking/mixing.
I like the idea of doing no tweaking at all in the DAW but I haven't managed that yet - mainly because I have yet to find a hardware reverb I like as well as my old Timeworks 4080l plugin and I have yet to find a hardware compressor I like as well as the Waves RenComp.
Fucking LOVING cassette recording btw. With the dbx on there is no tape hiss at all and the sound is fantastic - especially now that I have some outboard preamps and am not dependent solely on the 488's preamps (which aren't awful, but aren't amazing either).
I am one happy recorder now. It's SOOOO fucking great using moving parts again. It makes me smile every time I sit down to mix or record. Thanks again for everyone's help in me getting this sorted out! Appreciate y'all.
Not only did he not mix or master on Cassette - but He dropped the Casette into some really powerful tools - then mixed it with some Powerfull Tools - then he let Bob Ludwig master it in his magical Kingdom - it bears no resemble to a cassette recording at this point.
I always thought that was the case too, but I’ve since heard that it’s just the cassette tape and it was all done in the machine. I’m not sure which is true?…,but it’s probably somewhere in between.
I love Nebraska but I always thought it was an odd one to point to in order to affirm the status of the Portastudio. Bruce's original tracks sound like exactly what they were: home recordings, which totally worked for those tunes (after a good bit of mixing and mastering).
But I've heard many other portastudio recordings that stood on their own as good quality recordings, including several by members here.
Here is an example of one of my early 4trk recordings. This was on a TEAC 3340S reel to reel, mixed to a cassette deck.
I didn’t have a mixer so I plugged the mics directly into the tape deck. For mixdown I had the little switch box that had 4 into 2 with (4) 3 position switches that gave you L, R, or Center for mixdown.
On this track we improvised 2 tracks then came back and improvised 2 more tracks over the first two.
Here's a story about it from the Tascam site as told by Bruce's Engineer. I always come back to it from time to time and you reminded me of it: https://tascam.jp/int/support/news/481
Just thought I'd add an update to this in case anyone else was dealing with similar issues, since I've hit on an interesting way to utilize both digital and analog in what I'm doing.
After playing a lot with other tape formats, I've continued to be drawn back to the 4 track cassette format for a variety of reasons. I don't have any use for digital as a recording format any longer, but I've found it makes an excellent *guide* or "map" for the tracks since it has no speed variance the way tape does.
So basically, every time I record a track on the tape machine now, I am simultaneously recording a track to the DAW as well. I then use the DAW tracks as a guide to line up the tape tracks after I import them. It's a pretty quick and easy procedure and once everything's lined up I delete the DAW tracks. Simple! It allows limitless tracks that are all fairly easy to line up.
This may well be a known trick, but oddly I haven't seen anyone mention it anywhere. It doesn't accomplish my goal of having no screens at all involved in tracking but it feels like a comfortable compromise.
Hopefully all this babble is helpful to someone.:)
So you're dumping the cassette tracks to the DAW and trying to line up the tracks. Don't you still get speed drift? I've done that when transferring old tapes to digital and there was always a bit of speed variation so that after 4-5 minutes there was a detectable difference.
Going from a turntable did the same. I was comparing a couple of phono cartridges, so I recorded the same song with each cartridge. Even over a single song, there was a difference.
In contrast, I took a recording that I did with my Sanyo camera, and my Zoom H4n. I brought both audio tracks into Reaper, lined them up on a drum hit, and 15 minutes later they were still in sync.
I have a vision now of somebody with a classic car getting a friend to also drive their brand new car on every journey just in case the classic car breaks down on the way, so if it goes wrong or starts to rattle, you can still get home?
Haha - Yeah, that's a decent metaphor, that isn't far off from my relationship with cars.:) I detest modern vehicles and smartphones, and although my cars don't have screens, I do appreciate the GPS on my wife's smartphone when we go on trips.:)
It's actually very easy to quickly line up the tracks - you can mostly do it visually even. There's no way to eliminate drift when using tape, and since I continue to prefer recording to tape and mixing in the DAW, this is the most idiot-proof method I've found yet.
The "slate" method for example gives you a sound to line things up to to start with, but as we discussed earlier in the thread, everything will drift considerably over the course of a song - especially a long song.
I should add that the first 4 tracks are always the rhythm section (drums, bass, guitar) so that everything else is arranged in time with those first 4. It's much easier to quickly line up a vocal track say, than it would be to add, say, a drum track as the 5th (or 6th or 7th, etc.) track. And I seldom use more than 7 or 8 tracks altogether. Not sure this would be ideal for more complicated projects but my stuff is pretty simple mostly.
