Quality of music
  • Thread starter Thread starter kathy21
QOL needs to be processed correctly to maximize bang for buck. I'd suggest an MBC called The Experience & reroute the results through Karma software to obtain something approaching a 50% blend & you'll have the piece reincarnated as a LOQ.
If you burn the result as a Wave file you'll some artifacts that can be floated in the Ganges bit stream processor passed onto an MPT & you may find that dithering will allow you to upgrade the sampling & bit rate so that higher end product allows you to listen & begin again.
I'm in a state of shock and awe at the shear profundity of your statement sir. My hat is off to you (but not broken).
Indeed sir, I forgot about the QQL processes and Karma software. Although I think that floating Ganges may be a bit extreme if youa re depressed with behringer. Thanks for the addition and illumination.
ok simple math for a complex question
esisttance+Music=life
Existance-music=dispare
18 beers+Dio-3 nightwish tracks= this awnser
any questions?
Stxrly
Replies
0
Views
262
Stxrly
Stxrly
FU$$_23_KC
Replies
1
Views
421
Slouching Raymond
Slouching Raymond
G
Replies
2
Views
958
Papanate
Papanate
