J
jnorman
in a certain sense, you can think of a compressor as an automatic gain control, like in a cheap tape recorder. the more you increase the threshhold setting, the more compression takes effect (soft sounds are amplified and loud sounds are reduced). at very high levels of compression, if no sound is being input, the gain in the compressor circuit is raised, and you will hear lots of room noises, then as soon as you input some signal, the gain goes way down, and all the room rumble/hiss goes away. when you stop playing, the compressor shoots the gain way back up again, as it tries to maintain a consistent signal strength - this is the pumping and breathing sound you get from high compression levels.
