problems with multiple m-audio soundcards
  • Thread starter Thread starter teddyastuffed
T
teddyastuffed
hey everyone! i have an issue with my soundcards that i dont know how to address. i had an audiophile 2496 and recently got a delta 1010lt and wanna use both for more inputs (duh !). anyways, i got everything working with my mixer (behringer ub2442) by pluggin all the direct outs of the 8 channels to the 2 inputs on my 2496 and the other 6 in my 1010lt. all the inputs can accept inputs (i tested all the inputs while watching the meters in the control panel), but the problem is that the 2 inputs for the 2496 go to the output on the 2496, where the 6 inputs for the 1010lt exit out the 1010lt's outputs. is tehre a way i can trigger the 6 inputs on the 1010lt to exit out the the 2496 (which then go back to my mixer for monitoring purposes)? i cant seem to figure this problem out.
and btw i am NOT daisy chaining my two soundcards using the spdif i/o's. i dont really want to unless i need to, but if thats the only solution then i will.
any input would be greating appreciated. thanks !
Well, this is one case where you do want to chain the s/pdif.
What you need to do here is get both cards in the same monitor mixer.
So...
1010 s/pdif out > 2496 s/pdif in.
1010 Patchbay set s/pdif out = monitor mixer.
2496 Hardware settings Clock = External.
2496 Patchbay set the out 1/2 = monitor mixer.
The 1010 monitor mixers stereo master output is now feeding the 2496 mixer on the s/pdif input fader.
Think you need to check multicard sync too, if not already done so.
wow thanks, imma try it out as soon as i can get a hold of a spdif cable ;o. thanks !
