I'll do some search, but in general how is the graphical dynamics processor different Glen?
I assume you are asking how it differs from a standard compressor? It's different in that it's not trying to emulate a standard compressor, and therefore does not limit itself as to what it can do to signal dynamics. A "compressor", as we commonly call them here, is technically specifically one particular kind of compressor - a broadband downward compressor.
With a dynamics processor, you can downward compress, upward compress, downward expand, upward expand, use multiple compression/expansion ratios at different signal levels, select the specific frequency bandwidth it works upon, yada yada yada. If it has to do with dynamics, it'll play with it somehow. And because it's not trying to emulate hardware, it doesn't limit itself (much) when it comes to the main settings of A/R times, threshold and ratio; if you cam punch in a number, it'll take it (within some reason, of course).
Here's a screen shot of the one from Adobe Audition 1.5, just as an example, but all of them I've seen have a similar format (with one exception, below) of having the graphical line on X/Y coordinates where the X scale represents input volume, and the Y scale the output volume. In this format a compression ratio of 1:1 is a solid 45° slope. By changing the angle of the slope or putting bumps or valleys in it, one can set up a custom compression/expansion curve with/without makeup gain as one wishes. The example shown has a 2:1 compression on everything up to -10dBFS, where it then hard-limits:
The one I prefer to use myself - and I often use this as my go-to neutral compressor, is the "Dynam-izer" plug from Roger Nichols Digital. The interface is far superior (IMHO) to the standard one above, and I've always like the surgical neutrality of the RND stuff. I carry a lot of the RND stuff with me wherever I go.
EDIT; YIKES! I just went to link to the RND site and it looks like they shut down operations as of just last week. It makes me wonder, if anybody is interested in what I consider to be the most underrated line of VST plugs on the planet, you might want to check the dealers and see if they're blowing out their inventories on this stuff.
G.
