Presonus Firepod problem
  • Thread starter Thread starter RVLVNGDRS
R
RVLVNGDRS
Hello,
not sure if anyone has experienced this problem with either the PS firepod or something similar, but here goes.
I'm using the firepod to record drums(6 channels). Using cubase SX3 and a firewire connection.
What's happening is as follows :
as im playing the track (6 channels), i can see the sound waves on my tracks pop up maybe 1 second late (doesn't usually happen), but it STILL appears to be recording all 6 tracks normally.......BUT, when i hit the stop button, the tracks sort of....shrink themselves and they play super fast and with LOADS of weird distorted noise.....the track is therefore barely audible.
i KNOW this is a problem with the firepod because ive never had this problem with any other gear in any other circumstance.
any suggestions/speculations?
Try recording in a different program and see if it still does the same thing. You can download something like Reaper for free and see if it does the same thing in it. that way, you can determine if the problem is with the Firepod itself or something like a configuration problem in Cubase. You need to narrow that down before you proceed.
I think you might have a sample rate issue. Make sure you're set at 44K for your sample rate on the firepod and in your recording program and then listen back, it should work.
what program are ytou using? the same thing was happening to me with adobe audition, but with a q10 not a firepod
Cubase SX3
