WykedPT
Member
So...apparently the 1818vsl 8 outputs can't be routed back to a mixer (analog) for more tweaking...It,s just a Audiobox 96 with 8 inputs and 2 outs....Am I right? ?
If I understand you (it's still a bit murky), you wish to run 8 analog outputs (TRS), from your DAW, out of the back of the Presonus, and onward to 8 analog inputs on your mixer. Mix or re-mix on the board and then return that mix, 2 track/stereo to your DAW.Hello......Was wanting to go from the audiobox back into my mixer to tweek the tracks a little more as I do the mix and then back into the DAW in stereo from the mixer. Signal from the mixer works fine going in but if I come out of the audiobox into the returns (tape returns) from the 8 outs on the back it only goes to 2 tracks and seems to sum the 8 tracks into 2 tracks. My mixer is a 48 channel recording mixer. I have the 8 tracks coming back in on channels 17-24 but only 2 channels (17 & 18) have playback. Any ideas would be great....Trying to get started in computer recording .Been doing analog and digital (ADAT and HD24) for awhile so it's a learning curve...Thanks
No that's not exactly what it means. Outputs 1 and 2 do share the stream with the Main Out 1 and 2. That won't cause a problem with accomplishing what you're trying to do. Don't physically route anything out of the Presonus Main Outs. No TRS cables on the Main Outs. Similarly, 7 and 8 shares an output. One output is to the headphone send and the other is to the TRS out 7 and 8. As long as you don't route both the headphone jack AND the 7 and 8 TRS to the board they will remain independent.Right..That's what I'm trying to do..I'm using Studio One Artist. Here's what the manual says which is rather confusing........".Line Outputs. The AudioBox 1818VSL has eight line outputs to route to external devices, such as headphone amps and DJ mixers. Outputs 1 and 2 share their playback streams with the Main Outs. Outputs 7 and 8 share their playback streams with the headphone output. Outputs 3 through 6 have independent playback streams." By this I guess it means the out aren't independent channel sends and everything is summed..
Another component you'll have to address. Since apparently 7 and 8 are the default outs for the headphone mix you'll have to adjust. Since setting up Studio One to feed independent outs (channels and tracks 1 through 8) to your mixer, as it stands there would logically be channels that would no longer be fed to the headphone outs.Thanks Joseph....I'll give it a shot.....
It's doubtful that your unit is defective - it's in the routing page for your Presonus - look where you can assign the 8 outputs - keep in mind that 1/2 outputs are the same as the Left And Right - and 7/8 are the same as the Headphone - those 4 outputs are stereo and the same thing as your Main L/R - Headphone outputs - Channels 3 to 6 are independent - so I would see if you can route stuff to the left and right and not the 4 Independent outputs - then you would have 6 outputs - 1 to 2 panned to Left and Right on the channels you want - and 3 to 6 as channels you wantI tried every combination I could on the 1818VSL (watched all the tutorials) and have come to the conclusion (after what should have been my first test) that the unit is defective. I have no signal from outs 3-8. I have signal from 1&2 and main out. Back to the drawing board and the 96 for now.. Thanks for the help....![]()
I'm with papanate in that I doubt the unit is defective and, like him, I suspect something is amiss in Studio One's I/O page and not the box itself. Anything is possible though. The 1818 was a pretty good interface and played nicely with Studio One's low latency "z" mode. So ya might wanna give the Presonus one more chanceI tried every combination I could on the 1818VSL (watched all the tutorials) and have come to the conclusion (after what should have been my first test) that the unit is defective. I have no signal from outs 3-8. I have signal from 1&2 and main out. Back to the drawing board and the 96 for now.. Thanks for the help....![]()
If you posted a screenshot of the I/O section in Studio One we could at least eliminate that as a possible source of the problem.
