preamp > preamp?
  • Thread starter Thread starter MemoGtr
MemoGtr
MemoGtr
Así o más verger?
i just got a preamp for my sm57. what i want to know is, am i suppossed to hook up the preamp to the mixer or directly to my soundcards line in?
For the cleanest signal path, put it directly to your soundcard. You would only put the preamp through the mixer if you wanted to mix that signal with others before recording to the computer. In cases where you do use the mixer, make sure you turn off the mixer's preamps
Cy
I generally put mine through the mixer just because its easier to control and i dont feel it changes the sound much if you dont put gain on the preamps. Of course it depends on what kind of mixer you have?
What kind of preamp did you get? I found the TRS direct out on the SP (awesome i dont remember the model :D) doesnt work too well so ive ran it from the XLR out into the mixer.
So it depends on what you want and how you feel.
Danny
Shortest & cleanest signal path is ALWAYS the way to go.
eaaaaaa! got that
but how do i turn off the preamps in my mixer? turning the gain all the way down or what?
Depends on the mixer.
My Studiomaster has a +48V switch that when turned on activates the phantom power on all xlr inputs.
Cy
The phantom power has nothing to do with turning your preamps on or off. It has to do with turning your phantom power on or off.
Basically youll wonna keep the gain level at Unity. This is usually marked by a U or a 0. Some mixers actually allow you to bypass the preamp but i think thats only in more expensive models but you can check that out. With the gain at U or 0 you wont be giving any more gain to the signal which allows the the least possible re-preamping possible although you will still get a little of the preamp coloring. This coloring like i said should be minimum but it will still be their, which is why it is just better to run it directly to input. But in my case its nothing i worry about too much.
Danny
eh! i turn all the gain down....but then i hear nothing hehe
G
Replies
2
Views
679
Papanate
Papanate
R
Replies
6
Views
690
rwestbrook64
R
Replies
19
Views
2K
rob aylestone
rob aylestone
