PRHunt
I void warranties
So what is the difference besides it the level being softer or louder?
On my Echo Audiofire8, selecting -10dBV on the inputs causes the unit to apply a digital signal boost after conversion. This is in the order of 12dB, which brings the signal up to a nominal +4dBu. (On the Audiofire range, this selection is made via the software console).
Your converter may be doing a similar thing? If you have your unit set to expect a signal at -10dBV (nominal), but the signal you feed it is actually at +4dBu (nominal), then you could be actually inducing an unwanted boost of about 12dB.
You'll find it worthwhile to do a search on dBV and dBu. The -10dBV standard ("consumer") is a average lower voltage signal than +4dBu ("pro", which is approx 12dB or 4x higher ). You should generally leave everything at +4 which is the standard nominal signal voltage for "pro" equipment.
If a switch if for "pad", it will generally be clearly labeled as such.
Paul
