Well Andy,
In the late 60's and early 70's I worked in the wafer fab at Tektronix and then at Intel. We were building monolithic and Hybrid opamps with 2 GHz unity gain opamps for Tek scopes at that time. I do not recall that there was any confusion between a potted discrete opamp and a hybrid or monolithic opamp.
In addition I recall no distinction between passive components and active components in the defination of discrete vs integrated.
So to me, based on 40 years experience in our industry your assertion is false.
You can make opamps out of tubes, discrete transistors and passives, a hybrid solution or a monolithic integrated circuit. (or any combinnation of the above) but you cannot make an integrated circuit out of discrete active or passive components. IC are by definition on a single die.
Of course, All those folks at Tek and Intel might be wrong.....
-E
I assume that you will not take my word for it. I do recall tube computers and my first transistor. I did work with an analog computer in school and more than a few discrete transistor based machines. My first IC based machine was a PDP-8I, Guess what the I stands for. (Well that and a 370)
Here is an excerpt from this URL
http://www.answers.com/topic/operational-amplifier
History
The operational amplifier was originally designed to perform mathematical operations by using voltage as an analogue of another quantity. This is the basis of the analog computer where op-amps were used to model the basic mathematical operations (addition, subtraction, integration, differentiation, and so on). However, an ideal operational amplifier is an extremely versatile circuit element, with a great many applications beyond mathematical operations. Practical op-amps, based on transistors, tubes, or other amplifying components and implemented as discrete or integrated circuits, are good approximations to the ideal.
Op-amps were originally developed in the vacuum tube era, where they were used in analog computers. Op-amps are now normally implemented as integrated circuits (ICs), though versions with discrete components are used when performance beyond that attainable with ICs is required.
PS
Tutor's tip: It would not be "discreet" (to show tact or reserve) to try to join "discrete" (consisting of unconnected or distinct parts) and competitive departments.
