Pre Pentium Technology.
  • Thread starter Thread starter Slackmaster2K
Slackmaster2K
Slackmaster2K
Gone
If it's a name-brand PC then chances are you're outta luck because the case design will be proprietary...even if you get a new case you might not be able to salvage everything making it more hassle than it's worth. (an upgrade is necessary BTW)
The CPU/bus/storage/memory requirements for recording 16bit audio at 44.1khz hasn't changed. You seem to have the impression that the software has just become more advanced, and therefore a faster computer is needed to run it. While software has become more advanced, the real power drain is the actual recording/playback/effect process itself, which has become MORE efficient in software.
PC recording is a relatively new thing. Computers just recently become powerfull enough for the average home consumer to build a nice flexible DAW without selling any limbs.
If you were to ask this question about a PII machine 5 years from now...I would say "go get an old version of n-Track" or something, since a PII based machine is adequate for flexible recording purposes. But a 486 is over the line....certainly you can understand that at some point computers had to become powerfull enough to perform a certain task. You wouldn't look for a recording program for a 286!
I would just part the sucker out. Save the hard drive if it's really a 4GB and not a 400MB. The drive will be slow by today's standards but can be used as a boot drive regardless. Sell the memory to some poor sap at outrageous prices (SIMMs are hard to come by today). If it has a VESA bus then throw everything plugged into it away because it's useless. And all the ISA card should be replaced as well. If you're lucky and it has PCI slots then you might be able to salvage the video card. If the case is standard AT then you can also use it to build a new system.
Slackmaster 2000
I've just found an old 486 DX2 66Mhz PC in my shed complete with 32Mb RAM, a 4 gig hard disk and a 16 Bit Soundcard. Surely at some time this would have been pretty fast kick ass machine. I know that the multitrack software being used presently would be no use on this machine, but what did people used to use before the Pentium was released?? Anyone got any ideas of multitrack software that will run on this machine. I know loads of people are going to say "buy a new PC", but if this machines just sitting in the shed rotting I thought I might try and make some use of it.
Pretty large hard drive for an old machine, someone must of upgraded it within the last couple years. I would look for an old pentium board and chip, used I'm sure you could find a Intel P55c 233MHz processor and board for around $50. Pop that in their, and keep the big drive. Maybe add a different soundcard, Creative Ensonic PCI, $20. With a cheap upgrade like that you could run most software, but would be limited to probably 8 tracks, maybe more though.
Emeric
Thanks for all the advice, it looks like it's going in the bin. I don't really want to bother upgrading it, for some strange reason I feel more comfortable with analogue recording (don't know why), I just thought if it could be of some use then I would keep it. I would have been happy if I could just have used it to mix down to stereo from my portastudio, but if its beyond redemption then i've lost nothing.
Now wait a sec...if you just want to use it for mixdowns then it should still work; assuming that the soundcard in it is half-way decent.
In that case just try running a wave editor like Goldwave that is capable of recording. Recording a single stereo track should be possible on that machine. I thought you were going to try and use it for more serious multitrack recording. Sorry.
Slackmaster 2000
Don't be sorry, its my question that was misleading, my original thoughts were for multitracking, the mixing down came as an afterthought, but I forgot to tell you. I'll drag it out & see how it performs.
