PhilGood
Juice box hero
OK! I've got my power supply together as well as the mic "clone", but before I connect them together I wanted a little more advice.
The filament voltage for the mic tube (6AU6) is at around 7.03v @ 3.36 mA with NO load, and the B+ voltage is around 303.2v @ 11mA with NO load.
All the resistors are the same as listed in the schematic and the caps are 22uF 450v on the B+ supply and ends for the B-, and 4700uF 35v for the filament.
Should I change the 10k resistor string to 15k's (or higher?) and the 45 ohm resistor to like an 80 ohm, or do you think I'm OK?
When I did my Royers, I noticed the outputs were much higher than the specs with no load and they are fine.
Whaddaya think?
Whaddaya think?
