antichef
pornk rock
OK - I've got an amp head with a 4-8 ohm max load (as labeled next to the output), and I've got a cab that's 16 ohms. I also have a Marshall "Power Brake" attenuator that has a switchable impedance setting - 8 or 16 ohms.
My question - if I set the Power Brake to 8 ohms (assume it's turned all the way up so that there's no attenuation), would it make it so that I could safely plug the 4-8 ohm head into the 16 ohm cab? (please don't say "try it and see"
Maybe you could get a dummy load resistor and run it in parallel with the cab.
