J
jeancoltrane
so i finally got around to trying this, and it seems to work pretty well. for anyone thats not familiar, it involves recording into your deck, then directly off the repro head into the daw in real time. for overdubs, you monitor the daw output via your interface or mixer and then use a delay compensation plug in to compensate for the gap between the record and repro heads so your overdub aligns back up in time. i'm using the voxengo plugin with logic pro, which seems to be working quite well with a few quirks. all the explanations ive read, you put the plugin on the channel you are currently recording to and it corrects the repro delay - but thats hasnt worked for me; i have to put the plugin on all the previously recorded tracks (and not the track im overdubbing to) and then the overdub will line up. hopefully im missing something obvious here, if anyone has experience.
im using a teac a2340 at 7 1/2 ips and even that speed seems to be near sample accurate, maybe 0-3 samples ahead or behind (the biggest difference being at the start of the reel vs the end) at 44.1 that would be an 'error' of less than 0.1ms, which im assuming is not a big deal timing wise. i'm guessing if i had a 15ips machine it would be sample accurate throughout.
obviously this is pretty cool, i now have an infinite number of tracks with my shitty 1/4" machine and dont have to worry about bouncing down or multiple rounds of conversion. i would love to stay all analog, but this seems like a good solution until i can get the dough together to make that happen.
i've even thought about picking up a mastering deck like an ampex 440, revox a77, or otari 5050 that i can use to track with, then off the repro head into the daw. i imagine that would give some huge sound without needing to get a 2" 16 track or whatever. my favourite sounding album ever (can - tago mago) was recorded using a revox a77, so i know you can get some sweet sounds direct to 2 track even if its a full band.
anyway, just curious as to who is using this method and what tips or experiences you may have - especially if youre using logic or a mastering deck to track with.
