I am sorry, but you have absolutely NO idea how sample rate conversion is done, and that is obvious from this post!
You can talk to all the professionals (who also seem to misunderstand how it is done too!) you want who agree with your totally wrong premise. That does not make your point any more valid.
When audio is sample rate converted, it is totally re-sampled at the new sample rate. The new samples are based upon algorithms that predicts how the original audio will make a wave form that can be re-sampled by an algorithm that predicts the new wave form of the audio.
The only "efficiency" that you might gain is that there are less samples to process at 88.2, but in NO WAY OR FORM is the process any more "simple" because the original sample rate is some number dividable by the target sample rate.
Actually, the source quality rule comes into effect, and quite the opposite is true! By having more samples available for re-sampling, and better re-sample is possible!
The biggest deciding factor on a sample rate conversion is the quality of the algorithm that is used, and the original quality of the file. If you can argue that 96khz potentially SOUNDS better than 88.2, then you can successfully argue that a SRC from 96 to 44.1 will sound better than a 88.2 to 44.1 will!
If you just think of it like this, it makes a lot more sense: The sample rate conversion is only as good as the source quality.
Get it now?
