I have the cheapy version of the Digitech,
the RP150 with only 50 presents, but haven't done too much with it so can't say how overall good it is when one takes the time to mix the various settings (distortion, reverb, echo, chorus, etc) to come up with custom sounds. Truth is I found one preset distortion effect with chorus and echo that I like better than all the others and have used it exclusively for the couple months I have had the pedal. You can hear it on my music page in Dawn Marie.
The pedal is pretty sturdy, and I think that once I get the chance to fiddle with the knobs a little it will be OK for recording. But it has a number of weaknesses that would prevent me from using on stage if I ever lose my mind and start doing that again:
- On my 150 and the 250 effects on/off is done by hitting both of the two buttons together, and it is really hit or miss -- mostly miss in my case. I don't think this is a problem with the 350 because the third button a dedicated on/off, but i would check.
- It requires the adapter -- will not run on batteries.
- The volume difference between clean and distorted effects is very significant. There is a volume setting that you can crank up and down as needed, and the volume setting does not appear to save like the levels on the various effects.
Hope this helps...
