Pod 1
  • Thread starter Thread starter smilestoned
smilestoned
Hi guys,
Can I upgrade sounddiver also for the pod 1 and can I then also use the presets from the tone transfer library or should I upgrade to pod 2?
Thanks..ron..
Thanks again but I don't want to upgrade to pod 2, no the pod is fine as it is.
I just wanted to know if i can use the upgraded software, sounddiver from emagic for editing trough midi, with the pod 1.
I guess I have just to try it.
why not, I mean, that's what the software is made for?
You cannot upgrade the POD with sounddiver. You can upgrade the POD by purchasing an upgrade processor and replacing the existing processor.
That said, you can probably use the latest sounddiver software with the POD, but I've got to warn you, it hasn't gotten any better.
If you're trying to use stuff from the tone transfer library that's designed for the extra models of the POD 2.0, then you simply can't use them without upgrading.
Slackmaster 2000
Yes, I'm have the latest upgrade from sounddiver and yes, it is still crap, very spartanic.
and I have found loads of libraries on the net for the good ol pod.
Thanx guys...
