please help
  • Thread starter Thread starter an1989dy
A
an1989dy
ok, i am going to give you my setup and you have to give me the best possibly way to get a good quality album for my punk rock band out of it...(not listing mics, but give suggestions on vocal and drum tracks)
Behringer Eurorack UB1622FX-PRO 16-Input Mixer
Behringer MDX 4600 dynamics processor
equalizer
reel to reel tape deck
Boss BR-1180 Digital Recording Studio
HP Pavillion 2.2 gb 512 mb ram with Cakewalk Homestudio 2004(i prefer to record to this if possible)
for guitars amps
Mesa Boogie dual rectifier
Galien Krueger backline 350
for control monitors i have a optimus stero reciever with good speakers hooked up
Behringer EuroPower EP1500 Power Amp with 2 speakers and floor monitor
well there you have it, please help me find a answer to all my problems...... good luck!
Direct ?
You will need a good quality soundcard and interface
Or one for transfers from your other gear
Stealthtech said:
Direct ?
more info please
Decide whether you're going to record on the Boss or the computer.
If it's on the computer, you'll need at least a 4 input soundcard to record the drums. You'll need something from the likes of M-Audio, Delta 44, Delta 1010LT.
If you can get 4 (8?) tracks on the Boss, then you can record on that and just transfer to the computer and do your editing & mixing in Cakewalk. Does the Boss have s/pdif?
what is an s/pdif and let me know how i could transfer to the computer
Wht is s/pdif
Hello all,
This is my first post.
Anyway, s/pdif, I'm a fan of it, I got one on my Boss VF1 and I love it.
It stands for Sony Philips digital interface format.
It's a solitary orange coloured RC socket, the same kind as your source inputs on your home hi-fi sets. (Phono in; Tape in; Tape out, etc.)
It gives a digital interface from your audio equipment to your PC or vice versa in stereo on a single RC cable. And all you have to do is plug it in.
No interference because of copper cabling because it's digital.
Hope that helps.
Unfortunately, I see that it is becoming more of a specialised interface, rather than a year or so ago it was almost a stock standard. Perhaps we'll all be moving toward USB 2.0 or FireWire.
Thez_Valken said:
Hello all,
Hope that helps.
Well - sort of.........
S/PDIF stands for Sony Philips Digital Interface. It's a self-clocking 2-channel digital protocol that IS fairly standard, allowing digital transfer of data between gear that adopts the specifiction.
The connection type for the protocol is NOT standardized - an S/PDIF digital stream can be transmitted through a variety of connectors - some similar in appearance to RCA jacks, others use optical TOSLink that looks like an ADAT connection. The connector itself is actually irrelevant, and unless it is specified, you can't tell what digital protocol is used for any given digital jack......
