J
JusAuser
Equipment:
Audiophile 2496 (soundcard)
MXL 990 condenser mic (microphone)
Art tube MP StudioV3 (pre amp)
Acid Pro 4 (recording software)
Problem:
After tons of trial and error now I can't get recording levels to work properly with Audiophile soundcard and the mic pre amp. I have to yell in the mic, to even come close to accepting any signal. Also, no wave patterned is generated in Acid. Because sound levels are too low.
Current Setup:
Mic is plugged into the Pre amp (thru input slot)
Mono (unbalanced) output w/ adapter (from pre amp)is plugged into PC soundcard's input slot.
Monitors are plugged into soundcard's output slot.
Suggestion:
Don't know where to even try to fix this problem. Spent tons of time reading threads that come close but don't help. Can someone please help...I really don't want to go out and by another pre amp.
Thanks in advance!
Problem:
Current Setup:
Suggestion:
Thanks in advance!
